UCM 6.1 LDAP Directory Integration
johnnystahlhut
What happen if I enable, and then disable the LDAP Directory Integration?
Do I loose all the users?
I ask because will see how many users there maybe will bee inactive.
Jaime Valencia
the new directory sync takes a copy of the directory into the server, so all the users will still be in the directory
you can find more here:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/directry.html
javalenc
if this helps, please rate
java
Jaime Valencia
javalenc
java
Thank you for you answer.
I have read the SRND but I was not sure about what happen with the inactive users after disabling the LDAP sync.
/Johnny
From your message, it appears that the users will stay in the UCM directory after a sync, no sync, but the documentation differs.
I just did a migration using DMA from 4.1.3 to 7.1.2. Brought over all users. Turned on Sync with AD, then turned it off. All users are gone. Not good. Any way to restore? We didn't do a backup before enabling the Sync.
Lessons learned?
