MeetingPlace and DC Directory
May 15th, 2008
Hello, i have MPE2.0 and CCM4.1.3.
CCM doesn't integrated with AD.
How can i view list of users in MPE?
Can i read DC Directory as LDAP???
i have next configuration on MPE.
LDAP URL: ldap://ccmsrv:389/
Directory name: Directory Manager (OR cn=Directory Manager,o=cisco)
Cisco base: o=cisco.com
User Base: ou=users,o=cisco.com
Directory type: default
Thanks.
Ginger Dillon Mon, 05/19/2008 - 09:55
Hi -
You can view the users from the MeetingPlace web page, Administration, by selecting User Profile Management. When MPE is integrated with DC directory, the first time your users log into the MPE user web page with their CallManager CCMUserid, an MPE userid is created using the default Group Management configuration you have selected. If you'd like, you can export your user information by performing these steps:
1. Under Maintenance, select Export
2. Select Profile Information
3. Select Destination - File
4. Select Headers
5. Select Create Report
6. Reply OK to the Please wait message
7. Save the resulting txt file
8. Open in Microsoft Excel
Hope this helps!
Ginger
A.Timoshenko Mon, 05/19/2008 - 21:01
Thx for the reply.
I found error.
port must be 8404 and i dont read about "When MPE is integrated with DC directory, the first time your users log into the MPE user web page with their CallManager CCMUserid"
after i read this, the problem was resolve.
