VPN Client: unable to import certificate from path
May 15th, 2008
This is the error I get when I try to import my user certificate from a pfx file.
Note: I've changed from Windows to Linux and I am using the same file I used succesfully in Windows.
Error:
Cisco Systems VPN Client Version 4.8.01 (0640)
Copyright (C) 1998-2007 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Linux
Running on: Linux 2.6.24-16-generic #1 SMP Thu Apr 10 13:23:42 UTC 2008 i686
[ Importing Certificate ]
Enter filename: hplive.pfx
Import Password:
Enter a password to protect your certificate.
Choose a password that you can remember.
Password:
Confirm Password:
error: unable to import certificate from path: /etc/opt/cisco-vpnclient/Certificates/hplive.pfx
Thank you in advance,
Fernando.
aghaznavi Wed, 05/21/2008 - 11:56
  • Silver, 250 points or more
The file path for the certificate may be incorrect or there may be a problem with the file system Please check that one.
mkumarchandu Thu, 12/29/2011 - 23:22
first import and clange .pfx to .cer using 'openssl' command and then import .cer certificate to certificate store. Hope this helps
