natted ip is not pinging from same server
May 15th, 2008
I have one server on that server one private ip is physical ip and 23 private ip are virtual ips and this server is behind the asa on inside interface .i have implemented one to one natting and it is working fine but when i am trying to ping my server public ip from the same server on which i have given natted private ip then it is not pinging but oin advanced some virtual ip are pinging and some are not pinging.
mail me on [email protected]
smahbub Wed, 05/21/2008 - 07:52
  • Silver, 250 points or more
can you provide the error message that you recieve while trying to ping the server which will be helping in identifying the cause of this issue and resolving the same.Also check for the NAT configuration on the device.
