Help with SFPs
Answered Question
May 15th, 2008
I have a 3750 with 12 SFP ports doing routing at a remote property. I also have a backup T1 connection on a 2821 Router. I need to be able to connect the the gig ethernet RJ45 connection on my T1 Router to a port on my 3750 switch so I can do HSRP. I am trying to find a compatible SFP module to work. I couldn't find anything on Cisco's website. Does anyone have any suggestions?
I found these items on google but I want to ensure compatibility.
Correct Answer by Sushil Kumar Katre about 8 years 5 months ago
Go for GLC-T SFP on the switch to connect to gig ethernet interface on the router.
GLC-T is supported on 3750 12 port switch model.
Have a look at the compatibility list -
-> Sushil
Overall Rating: 5 (1 ratings)
