Authentication Failure in Cisco Secure ACS v4.1
May 15th, 2008
Hi, I added a user in the Cisco Secure ACS and I am getting the following Authen-Failure-Code in Failed Attempts:
EAP-TLS or PEAP authentication failed during SSL handshake.
When I run Support in System Configuration > Support, I get the following in the auth.log:
AUTH 05/15/2008 16:55:40 I 0928 3320 AuthenProcessResponse: process response for 'FE:A3:C4:00:32:40'
AUTH 05/15/2008 16:55:40 E 0381 3320 EAP: TLS: ProcessResponse: SSL handshake failed, status = 3 (SSL send alert fatal:decode error)
AUTH 05/15/2008 16:55:40 E 0381 3320 EAP: TLS: ProcessResponse: SSL ext error reason: 87 (Ext error code = 0)
AUTH 05/15/2008 16:55:40 E 0381 3320 EAP: TLS: ProcessResponse(1519): mapped SSL error code (3) to -2120
Does anybody know, what the issue could be. I was able to find info about 2120, but don't know what exactly this means, other than that the authentication failed:
UDB_EAP_TLS_HANDSHAKE_FAILED
Thank you,
Jutta
Jagdeep Gambhir Sat, 05/17/2008 - 05:13
Jutta,
SSL alert fatal:decode error: That means basically, the client has a problem with decoding the root certificate.
Please make sure that client has CA installed. If you are doing peap and uncheck validate server certificate on wireless setting on the client.
~JG
Do rate helpful posts
