Static Routing with timers
May 15th, 2008
Hi all,
We are using DXX as a primary link and I-Direct as secondary link between our Head Office and a branch office in other city. We are using static routing for automatic switching between the links i.e. when DXX goes down I-Direct comes up automatically. These days our DXX is fluctuating. This creates alot of trouble. Is there any thing as a timer on static routes that if our DXX is down and I-Direct is working and suddenly DXX comes up so I-Direct should wait for a certain hold down time before switching back to DXX.
Thanks in advance.
- Jay
Overall Rating: 5 (2 ratings)
ariela Thu, 05/15/2008 - 23:01
which type of interfaces do you have?
In general, you can use a 'backup interface' command with a specific 'backup delay'.
backup delay 10 30 ! 30 is your 'hold down time
backup interface
Remember: it's important that on during the fault the encapsulation goes down to use correctly the backup interface
jaykishan Fri, 05/16/2008 - 02:00
Thanks alot Andrea, your sugesstion solved my problem. You are the best.
