Intracluster Extension mobility in 6.1
Aaron Harrison Fri, 05/16/2008 - 03:54
Assuming you mean INTERcluster EM (between multiple clusters), no.
Enhancements to EM in 6.x allow it to operate without the Publisher being available, but inter-cluster EM still isn't in there.
INTRAcluster EM (i.e. within a cluster) has been there for many versions.
Hope this helps
Aaron
Please rate helpful posts.
Sushil Kumar Katre Fri, 05/16/2008 - 08:15
What Aaron has mentioned is correct.
Inter Cluster Mobility is not supported by UCM 6.X and is not going to be available in UCM 7.X [upcoming release].
However with intra cluster mobility which is there for quite some time there was a restriction that if the publisher goes down, users can't use extension mobility since that requires read access to the UCM database and subscriber database does not have read access.
With UCM 6.X there is an enhancement which is that even if the publisher goes down users can use mobility because extension mobility access right are rovided on the subscriber now, so subscriber can make datanase changes related to mobility.
By Mobility I mean extension mobility.
Hope this helps.
-> Sushil
Michael Owuor Fri, 05/16/2008 - 12:27
What used to be Metreos application is now the Cisco Unified Application Environent (CUAE).
CUAE has a cross cluster Extension Mobility application.
http://www.cisco.com/cdc_content_elements/metreos/download/Metreos_ClusterMobility_WhitePaper.pdf
http://www.cisco.com/cdc_content_elements/metreos/products/applications.shtml
http://www.cisco.com/en/US/products/ps7058/tsd_products_support_install_and_upgrade.html
Hope this helps.
Michael.
