enable ipsec over nat-t disappear
May 16th, 2008
Hi all,
I've this annoying problem.
I've a pix525 with 8.0(3) release, and I've enable Nat-t, with
checkbox (from Configuration - Remote Access VPN - Advanced - IKE Parameters).
Pix525 is connected in failover configuration to another pix525.
When I reload one firewall, this configuration disappear, so I must reenalble it everytime this happen.
I've noticed that this happen also with a couple of ASA5510 and of PIX515, with same release.
If I disable failover (and I use only one firewall), this doesn't happen.
Any idea?
I have seen this myself using the ASDM, configure the setting from the CLI and wr mem. Especially lookout for:-
device# wr mem
Building configuration...
Cryptochecksum: 65765026 3c703ddd 8d529956 e7239708
30935 bytes copied in 3.640 secs (10311 bytes/sec)
The above indicates the primary device has written the config changes to the standby device.
acomiskey Fri, 05/16/2008 - 06:20
I think this is a bug. The workaround is to use a nondefault value...
crypto isakmp nat-traversal 21 (not the default 20)
