RDBMS Sync - Process error
mvamvakaris
i want to import aaa clients and after the synchronisation appears following error in the log:
Sync complete: 5 transaction(s) 0 parse error(s) 1 process error(s).
the aaa clients are not importet to the acs and i don't know whats the process error mean.
its a appliance 1113 with the acs 4.1.1.23.5 patch.
the accountActions.csv file should be ok.
the rdbms sync is enabled and i can see the log entry but the clients will not be added.
mattjenkins
HIi,
It appears you have semi-colons (;) in the file not comma's (,).
Change them and it should work
