CCNA needed for CCVP if already CCIE?
May 16th, 2008
I'm interesting in studying voice and am thinking of doing the CCVP track. I do not have a CCNA but I am a CCIE. CCNA is listed as a prereq for CCVP. Does my CCIE trump this requirement?
Thanks, Gregg
Overall Rating: 5 (1 ratings)
rainer_rudigier Fri, 05/16/2008 - 03:33
if you had a valid CCNA certification at the time you did your CCIE - the CCIE should have recertified your CCNA ..
if you never did take the CCNA - you have to take it to get the CCVP certification
the CCIE doesn't trump that :-(
you can check that in the cisco certification tool ..
_rainer
gregg.malcolm Fri, 05/16/2008 - 04:36
Thanks Rainer. I thought so but wanted to make sure. On to the CCIE voice written for me.
Gregg
rainer_rudigier Fri, 05/16/2008 - 04:52
glad to help
I am also working towards the Voice written - my plan is to tackle the written mid next year and use it to recert the R&S with it
_rainer
Brandon Buffin Fri, 05/16/2008 - 09:06
Gregg,
I would recommend checking with certifications support on this as the CCIE does waive the CCNA for CCDP. I would assume it also does for CCVP. See the following link.
http://ciscocert.custhelp.com/cgi-bin/ciscocert.cfg/php/enduser/std_adp.php?p_faqid=3724&p_created=1176492945&p_sid=LW_w_T3j&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTIzLDEyMyZwX3Byb2RzPTAmcF9jYXRzPSZwX3B2PSZwX2N2PSZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PWNjaWUgY2NkcA**&p_li=&p_topview=1
Hope this helps.
Brandon
