Question on Access points with WPA and AES Encription...
May 16th, 2008
Laptops users or PDA's user not able to access the AP when i use the WPA with AES Encription.
Where as it works fine with WPA with TKIP.
Kinldy someone let me know if this works?
Overall Rating: 5 (1 ratings)
dennischolmes Fri, 05/16/2008 - 05:33
  • Gold, 750 points or more
It will work if your client device supports AES encryption. Most older client device chipsets do not support AES.
Sarasaqlain Fri, 05/16/2008 - 06:04
HI Dennis,
Thanks for the information.
Could you please let me know your opinion on this:-
AP 1121:-
PDA's users are not able to connect to AP while using WPA with TKIP encryption. Where as laptop users are able to connect to AP.
Kindly let me know if there is some configurtion that i need to look on.
Any suggestions on this would be appricaited.
