ASA webvpn securID and AD login
Hi all
I am trying to set up a clientless access with both RSA and AD login on the portal login page. It is possible to "allow user to enter internal password" at the same time as securID passcode if the user is the same in both AD and ACE server (using auto login feature works too). But I noticed that if you enter wrong "internal password" you get access anyway,and have to enter it when accessing intranet link i.e. Also AD password expire wont work. Is it at all possible to make this work in a better way? that is, user denied access with wrong internal password and password expire notification.
