2 unity servers single domain
May 16th, 2008
hi we have 2 unity servers within a single AD - will the servers automatically network, i.e see eachother and can subscribers pass messages between servers.
Also is there a way of disabling this if necessary?..cheers, jag
Overall Rating: 3 (3 ratings)
Brandon Buffin Fri, 05/16/2008 - 05:46
See the following link for the required and optional configuration steps to use digital networking with Unity. Yes, you can restrict the ability of subscribers to exchange messages by limiting the search scope. This is also described in the link below.
Hope this helps. If so, please rate the post.
askq2forum Fri, 05/16/2008 - 06:23
Brandon, thanks for your reply. We have a number of server within same domain but managed by 2 different helpdesks. How can we stop 1 from viewing and making changes to the other.?
Brandon Buffin Fri, 05/16/2008 - 06:33
Administrative access is controlled by CoS. If a user does not have a subscriber account or an account associated with a subscriber account with a Class of Service that allows access to a particular Unity server, they will not be able to administer that server.
Hope this helps.
Tommer Catlin Fri, 05/16/2008 - 06:52
You can also use GrantUnityAccess to take/or give access to the respective Unity boxes. If they share the same Unity Service accounts, might be a little tough.
