MPLS causes MARS unconnected "clouds" on serial interfaces
May 16th, 2008
In MARS we have a graphical layout of our network and athe things being monitored.
When the routers to our branch routers are shown, since the the serial interfaces are on two host point to point networks, the serial interface is connected to a cloud.
Each branch connects to a seperate cloud.
Is there any way to have all branch serial interfaces go into the same cloud?
Overall Rating: 5 (1 ratings)
pmccubbin Fri, 05/16/2008 - 07:03
  • Silver, 250 points or more
Hi Richard,
There is no way at present that I am aware of to do this. It's a fairly common request from my customers to have a greater ability to customize the graphical layout of the network map. I have made this request to Cisco to add this functionality.
Hope this helps.
Paul
clausonna Mon, 05/19/2008 - 06:01
  • Bronze, 100 points or more
At one point I thought about creating a 'fake' router in MARS that would have interfaces with IP addresses that correspond to the PE (Provider Edge) MPLS routers. This would mean creating a "Generic Router version unknown" in MARS and standing up a 871 or something so that MARS can SNMPWALK it.
Afterwards I thought you could add the PE interfaces and the maps would glue the subnets together. I haven't tried this yet, but in theory it should work, right?
