How to remove Manager/Assistant setting
Answered Question
May 16th, 2008
In evaluating the Manager and Assistance feature of CallManager 4.2(3), I configured phones for the test that place a DND (Do Not Disturb) logo on the Manager's phone. Now I want to re-use th phone but can't seem to remove this graphic from the 7940's display.
Any Help?
Correct Answer by Brandon Buffin about 8 years 5 months ago
See the following link.
Hope this helps. If so, please rate the post.
Overall Rating: 5 (1 ratings)
c.yeo Fri, 05/16/2008 - 11:11
Thanks, rather counter-intuitive...remove the IPMA services from the Assistant phone to clear up setting on the Manager phone .
I had already removed the users associated with the phones, so I had to re-create the Manager/Assistant relationship in order to remove the IPMA services.
Thanks again,
Jaime Valencia Fri, 05/16/2008 - 09:11
have you changed the phone button template for that phone to a normal one?
if this helps, please rate
c.yeo Fri, 05/16/2008 - 11:12
Yes, I had change the phone button template. That controls the softkeys, but the backgrownd graphic associated with the Manager/Assistant configuration was persistant. The previous post to remove the IPMA services from the Assistant phone, cleared up the residual effects on the manager phone.
