05-16-2008 09:54 AM - edited 03-05-2019 11:02 PM
I have a few 3750 in a stack...how do I view the utilization on those stack ports? I'm thinking about replacing them with 3560G switches with a few trunk ports in an etherchannel but I want to see what the utilization is on the stack to see if that's even possible.
05-16-2008 10:20 AM
show switch stack-ring activity [detail]
HTH,
__
Edison.
05-16-2008 10:34 AM
Yea I saw that command...I guess i don't understand how to read the output. :)
Switch Asic Rx Queue-1 Rx Queue-2 Rx Queue-3 Rx Queue-4 Total
1 0 1250220656 737509322 131742031 0 2119472009
1 1 8 0 -1216228079 0 -1216228071
1 2 8 0 113849949 0 113849957
1 3 8 0 393453140 0 393453148
1 4 8 0 - 308391361 0 - 308391353
1 5 8 0 -2080199764 0 -2080199756
1 6 8 0 1532677337 0 1532677345
Switch 1 Total: 554633279
2 0 1244030790 747060438 0 0 1991091228
2 1 8 0 -1564944181 0 -1564944173
2 2 8 0 76389016 0 76389024
2 3 8 0 469796624 0 469796632
2 4 8 0 524559872 0 524559880
2 5 8 0 1345695311 0 1345695319
2 6 8 0 - 377692604 0 - 377692596
Switch 2 Total: -1830071982
3 0 1137030913 869068912 38422167 0 2044521992
3 1 8 0 88469136 0 88469144
3 2 8 0 52744350 0 52744358
3 3 8 0 1636555667 0 1636555675
3 4 8 0 -2006883211 0 -2006883203
3 5 8 0 2077661011 0 2077661019
3 6 8 0 -1146969797 0 -1146969789
Switch 3 Total: -1548868100
Total frames sent to stack ring : 1470660493
What does that mean...what's the current utilization?
05-16-2008 12:52 PM
The value indicated in the output reflects the number of frames that are sent from each switch to the stack-ring.
You also get information regarding the received queues per stack member.
It's not as straightforward as viewing input/output packets from an single interface but that's the only output available to find out the amount of traffic sent to/from the stack.
As per your original post, what's the driving factor from moving from a stacking solution to a standalone solution such as the 3560G?
HTH,
__
Edison.
05-16-2008 01:10 PM
Our 3750 switches are only 24 port, and we're running out of ports. We have a few spare 3560G 48 port switches, so we were thinking of just replaces the 3750's with those, and creating 2GB fiber trunks. My biggest concern with that is these are very active switches (They handle a lot of live data), so I'm not even sure 2GB uplinks will be enough, especially considering the etherchannel load-balancing doesn't evenly split the load between the ports.
05-16-2008 01:44 PM
Use the "show controllers utilization" command , it tells you exactly how busy it is in % at the bottom of the display . It also shows what percentage utilization each and every port in the stack is running also. It does not break it out to what each member is transmitting just the the whole stack though you can probably get a pretty good idea whats going on by just looking at the ports .
