alow-tls
Answered Question
Hi, I have a PIX 515E and a Windows SMTP Server in a DMZ, and I need send to some customers encrypted emails using TLS. I read in a Cisco documentation that I need enable it if use inspect esmtp:
policy-map type inspect esmtp esmtp_tls_enable
parameters
allow-tls
policy-map global_policy
class inspection_default
Now, when I do it, TLS work fine and I can send encrypted email but for unknown reason I can't send o receive non encrypted emails from other customers.
We can help me with this issue?
Correct Answer by vitripat about 8 years 8 months ago
I'm glad, could help you.
Vibhor.
Overall Rating: 5 (1 ratings)
vitripat Sat, 05/17/2008 - 19:12
I think the issue here is with the some EHLO parameter which is not supported by ASA. Try adding following commands-
match ehlo-reply-parameter others
mask
Clear the mail server connections through ASA and check if mails work now.
How this helps.
Vibhor.
Hi Victor, thanks for your reply, I've done it and it work fine. Now I can send emails using TLS and regular emails.
The final configuration is:
parameters
allow-tls
mask
Best regards,
Correct Answer
vitripat Fri, 05/23/2008 - 14:03
Vibhor.
