Cisco 877 ADSL Line Operating Range
May 16th, 2008
Hi:
I'm trying to put a specification together for our help desk to deal with DSL line problems. What I'd like to pass along to them is a range of acceptable line measurements as seen by the routers 'show dsl interface atm 0' command output. In particular, what are the acceptable ranges for ATU-R and ATU-C values of: Noise Margin, Output Power and Attenuation. The router uses the Alcatel 20190 chipset.
Thanks.
Dale
Haris P Sun, 05/18/2008 - 04:34
  • Bronze, 100 points or more
Dear Dale,
As I know, There is no specific values ,but you can consider the following ranges to troubleshoot the dsl issues .
For Noise Margin: (the higher this value, the better)
8-13 Average
14-22 Very Good
23-28 Excellent
For Attenuation: (the lower this value, the better)
20-30 Excellent
30-40 Very Good
40-60 Average
Also incresing the Increasing the transmit power levels will also improve the noise margin but at the cost of interfering with other services in the same cable.
Haris
