05-16-2008 12:21 PM - edited 03-10-2019 03:51 PM
Can anyone tell me if I can console into a Cisco Access Control Server using the blue console cable and Hypertext Terminal? If you can, what do the settings need to be for Hypertext Terminal? It seems that Cisco has removed the configuration manual for ACS from their website.
Solved! Go to Solution.
05-17-2008 04:57 AM
King,
Here is the link,
~JG
Do rate helpful posts
05-17-2008 04:57 AM
King,
Here is the link,
~JG
