Mark Yeates Fri, 05/16/2008 - 19:33
  • Gold, 750 points or more
Bassam,
I don't believe that memory (flash or dram) can be upgraded in these kinds of switches. These are fixed configuration switches, designed to operate at their current capability. I did look and did not see a part number for larger memory chips for the 3560. Unlike most routers and modular switches they are not upgradeable memory wise.
Mark
Bassamkareem Fri, 05/16/2008 - 20:00
Thanks mark for your quck response so what i have to do when there is a problem in memory can change or not ?
Mark Yeates Fri, 05/16/2008 - 20:11
If you are having memory problems you should contact TAC. I Highly doubt that memory modules in the switch are field replaceable.
Mark
