Unity Connection 1.2 applying 2003 SP2
sposte
After a memory leak caused Unity services to stop on a UC machine, TAC recommended applying SP2 because some known memory leak problems were fixed with the update.
Any problems I should be aware of?
Scott
Tray Stoutmeyer
Is this Windows 2003 sp2 you speak of or are you referring to the UC 1.2 SR2 release? If anything I would also update UC 1.2 to the SR2 on top of the SP2 for Windows 2003 and get your system as up to date as possible. Both should be safe to apply and fix many a bug. The SR2 for UC 1.2 is available on the Voice Software downloads on CCO.
Tray
Thanks, I'm referring to the OS only. The Unity has SR2 applied.
SP2 should be fine on the OS in UC 1.2.
Tray
