How to download crashinfo file?
Answered Question
May 17th, 2008
Hey guys,
I would like to know about downloading crashinfo file from the flash drive.
Pls see below:
RSW01#dir
Directory of flash:/
2 -rwx 5708466 Feb 28 1993 19:57:48 -06:00 c2960-lanbasek9-mz.122-35.SE.bin
3 -rwx 1048 May 16 2008 02:13:55 -05:00 multiple-fs
4 drwx 64 May 16 2008 12:01:33 -05:00 crashinfo_ext
5 -rwx 616 Feb 28 1993 18:00:27 -06:00 vlan.dat
6 -rwx 1916 May 16 2008 02:13:55 -05:00 private-config.text
7 -rwx 16027 May 16 2008 02:13:55 -05:00 config.text
9 drwx 64 Feb 28 1993 18:00:02 -06:00 crashinfo
32514048 bytes total (26468864 bytes free)
RSW01#more flash:crashinfo_ext
%Error, "flash:crashinfo_ext" is a directory.
I can even read it since it is a directory.
IS there a way for copy that file (or directory)?
Thank you
siraj
Correct Answer by Richard Burts about 8 years 10 months ago
Siraj
If it is a directory then try dir of that directory. something like dir flash:crashinfo_ext
and if the dir does show a filename then use the pathname and filename in the more command. something like:
more flash:crashinfo_ext/
Give that a try and let us know what happens.
Rick
Overall Rating: 5 (1 ratings)
sirajmuneer Sat, 05/17/2008 - 01:18
Nope, command not unrecognized.
SW01#sh crashinfo ?
% Unrecognized command
sirajmuneer Sat, 05/17/2008 - 01:33
I have tried all the commands on that link, but the problem is, this device is treating crashinfo as directory instead of file.
See here:
SW01#sh file in flash:crashinfo
type is Directory >>>>
Thanks anyway for link, bvs
regards
siraj
bvsnarayana03 Sat, 05/17/2008 - 01:57
  • Silver, 250 points or more
it mentions that "sh stack"
& "sh tech-support" shows the crashinfo. You may extract those files.
Correct Answer
Richard Burts Sat, 05/17/2008 - 09:30
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Siraj
Rick
Richard Burts Sun, 05/18/2008 - 03:27
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Siraj
I am glad that my answer helped to resolve your issue. Thank you for using the rating system to indicate that your issue was resolved (and thanks for the rating). It makes the forum more useful when people can read an issue and can know that there was an answer that did resolve the issue.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
