05-17-2008 04:49 AM - edited 03-15-2019 10:42 AM
Were looking to integrate a Valcom IP paging system. Says it integrates via sip trunk. If we have CME with just pots dial-peers and no h.323 running, can we do a sip trunk off the CME router (running standard voice image) without having to pay for sip license (ip2ip gateway)?
thanks
Solved! Go to Solution.
05-17-2008 11:08 AM
No license is needed. ip2ip gw is needed for other things, not what you want to do.
05-17-2008 11:08 AM
05-17-2008 02:58 PM
Thanks Paolo
05-17-2008 03:01 PM
You're welcome, thanks for the nice rating and good luck!
10-24-2010 01:58 PM
I'm looking to do something similiar. How did it work out? Which Valcom did you use?
