CME - need clarification on which version for 12.4.17a
May 17th, 2008
I see two versions that support mainline 12.4.
cme-basic-124-1.tar and cme-gui-124-1.tar
cme-basic- and cme-gui-
Are cme-basic- and cme-gui- specifically for IOS 12.4.3 but I would use cme-basic-124-1.tar and cme-gui-124-1.tar for every other 12.4 mainline version?
Paolo Bevilacqua Sat, 05/17/2008 - 11:05
Hi, in reality there is not much difference, the zipfiles contains the gui mainly (that does little anyway) and phone firmware files.
You may evaluate instead of using a newer version because 3.3 is quite old and not up to par wit today's customer requirements.
Stability is he same, ie, a mainline is not any more stable than a cme version.
kbyrd Sat, 05/17/2008 - 12:47
Thanks for your reply. I realize that newer CME versions have more features, but I also need the WAN - which this router's other function - to be very stable.
