BGP Question
May 17th, 2008
Is it possible that same distination reach via diffrent ISP but metric value is same.? and that destination route is install in "Show ip route" table. Please let me known.
-M
1 vote
Overall Rating: 4.8 (6 ratings)
Giuseppe Larosa Sat, 05/17/2008 - 10:49
Hello minu,
yes you can have two different eBGP advertisements installed in your routing table for an IP prefix.
Look at the command maximum-paths in the router bgp process. The default value is 1. if you use maximum-paths 2 you can have two paths installed in your ip routing table.
If you want to compare MED for advertisements coming from two different ISPs (BGP ASN) you can use the command
router bgp
bgp always-compare-med
! and to have a deterministic behaviour
bgp deterministic-med
maximum-paths 2
hope to help
Giuseppe
Harold Ritter Sat, 05/17/2008 - 17:16
Giuseppe,
Bear in mind that IOS will not install the two paths in the RIB by default if they are not from the same neighbor AS.
You can use the following hidden command to change this behavior.
"bgp bestpath as-path multipath-relax"
lamav Sun, 05/18/2008 - 08:59
Thats interesting...
So, the maximum-paths command is only for installing multiple paths from the same neighbor?
Victor
minumathur Sun, 05/18/2008 - 18:41
That mean in " show ip route" do not have multiple routes for same destionation only this is happend with same AS not different different AS.
Please correct me if i am wrong..
-Minu
royalblues Sun, 05/18/2008 - 23:54
yes.. if you have maximum-paths configured under BGP, and you receive multiple routes to the same destination via different AS, it will not be installed in the routing table
you need to enter the command that harold pointed out
configuring the above along with the maximum-paths will ensure that multiple entries are installed in the RT
Narayan
Narayan
minumathur Mon, 05/19/2008 - 23:11
Hi Narayan
I beliave maximum-path command only use only AS. that means it is useful when you have two link with same AS, here my question is the if i have two links with different AS and it will design in such way that i will have all attributes are same , in that case should i get two routes in "show ip route "
-minu
royalblues Mon, 05/19/2008 - 23:34
Minu,
When you enter the bgp best-path as-path multipath-relax command along with maximum paths command, the router will install 2 routes provided the other attributes are same
here is an example output where R1 (AS 100) is connected to both R2 (AS 200) and R3 (AS 300) both advertising prefix 1.1.1.0/24
R1
router bgp 100
no synchronization
bgp log-neighbor-changes
neighbor 10.10.10.2 remote-as 200
neighbor 20.20.20.2 remote-as 300
maximum-paths 2
no auto-summary
R2
router bgp 200
no synchronization
network 1.1.1.0 mask 255.255.255.0
neighbor 10.10.10.1 remote-as 100
no auto-summary
R3
router bgp 300
no synchronization
neighbor 20.20.20.1 remote-as 100
no auto-summary
r1#sh ip bgp
BGP table version is 3, local router ID is 20.20.20.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 1.1.1.0/24 10.10.10.2 0 0 200 i
* 20.20.20.2 0 0 300 i
r1#
r1#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
1.0.0.0/24 is subnetted, 1 subnets
B 1.1.1.0 [20/0] via 10.10.10.2, 00:07:53
[20/0] via 20.20.20.2, 00:03:49
20.0.0.0/24 is subnetted, 1 subnets
C 20.20.20.0 is directly connected, FastEthernet0/1
10.0.0.0/24 is subnetted, 1 subnets
C 10.10.10.0 is directly connected, FastEthernet0/0
r1#
Note : it is possible that the command may not appear in the CLI help but you can type it as it is
Narayan
lamav Tue, 05/20/2008 - 06:47
Narayan:
Nice presentation. There's no better way to prove the theory than to actually put it to the test.
I rated your post.
Victor
philiechang Tue, 05/20/2008 - 08:19
Narayan,
Since both paths are installed into the routing table does this mean it will load-balance between the 2 routers?
Phil
royalblues Tue, 05/20/2008 - 20:31
Yes it would and would be based on the CEF per destination loadbalance by default
Narayan
minumathur Wed, 05/21/2008 - 00:11
thanks for clarification , this is really great help, onces again thanks
-minu
Giuseppe Larosa Tue, 05/20/2008 - 02:31
Hello Harold,
I thought that the usage of the command bgp always-compare-med was enough to achieve the intended result.
From
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_bgp1.html#wp1011748
To enable the comparison of the Multi Exit Discriminator (MED) for paths from neighbors in different autonomous systems, use the bgp always-compare-med command in router configuration mode. To disallow the comparison, use the no form of this command.
Actually, I haven't tried what I was suggesting.
Thanks for your correction.
Best Regards
Giuseppe
Harold Ritter Tue, 05/20/2008 - 05:00
Giuseppe,
This command will only force the comparison of MEDs between different ASes. It doesn't mean both paths will be installed if the MEDs are equal.
You absolutely need the hidden command "bgp bestpath as-path multipath-relax" to get the two paths to be installed in the RIB.
