can native vlan 1 be blocked using dot1q/ISL?
sarahr202
Level 5
Level 5
hi every body!
I want to know can i block nativa vlan 1 by:
switchport trunk allowed vlan except 1
or
switchport trunk allowed vlan remove 1
Using ISL:
switchport trunk encapsulation isl
or
thanks!
2 Accepted Solutions
bvsnarayana03
Level 5
Level 5
You cant remove native vlan from trunk. However, you can change the native vlan from default of 1 to some other vlan number.
"switchport trunk native vlan x"
Jon Marshall
Sarah
As already mentioned you can change the native vlan to be something other than vlan 1. The native vlan is simply the vlan that is sent across a trunk without a tag. By default it is vlan 1.
Cisco recommend using a dummy vlan for the native vlan ie. a vlan that is not routed and has no devices connected into it.
If you make the native vlan a vlan other than vlan 1 it is important to note that vlan 1 will still be used to send DTP,VTP,PagP frames which will be tagged.
You can if you want to make sure that the native vlan is tagged by using the command
vlan dot1q tag native
Jon
bvsnarayana03
Level 5
Level 5
thanks for your reply. I applogise for posting multiple instances of same post by mistake.
Have a nice day!
Jon Marshall
Sarah
Jon
Thanks jon for your reply!
