Unity Express
May 17th, 2008
How can I do to telnet Unity Express (NM-CUE) remotely?
I'm in site A and the NM-CUE is in Site B, I need upgrade language and I can't telnet to NM-CUE, just GUI. It's normal?
Kenneth Mohammed Sat, 05/17/2008 - 13:51
Telnet to the router at Site B. Once in the site B router, type the following:
service-module service-engine x/x session
(You can do show ip interface brief to get the slot the CUE is in and replace the x/x accordingly)
or if you have a newer CUE model, type
service-module integrated-service-engine x/x session
That should get you in.
Hope that helped, if so please rate.
Paolo Bevilacqua Sat, 05/17/2008 - 14:25
To add to the good advice by Kenneth, you can also telnet directly, IP of the router, port 2194.
