Vista VPN Woes
May 17th, 2008
Hi all,
I am using an ASA 5540 software version 7.0(4) with Cisco VPN client version 5.0.03.0530. I have a VPN group setup that works fine on XP and fine on Mac, but has major issues on Vista.
The VPN is setup so that the only traffic that gets encrypted is some DNS traffic, and some traffic to some file servers. All other traffic on the clients get bypassed.
I can confirm this on an XP box using Wireshark. If I sniff the traffic of just going to a web page, the only thing that shows up on the VPN adapter is some DNS traffic, all of the TCP traffic goes out the regular interface, and the web page loads fine. If I do the same sniff on Vista, the TCP SYNs go out of the VPN adapter, and it never gets a reply, and the web page never loads. All of the route details are exactly the same on the Vista box as they are on the XP box, I have no idea what is causing it to act different.
Any help is appreciated, thanks.
Richard Burts Sun, 05/18/2008 - 03:33
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Robert
The symptoms sound like it might be some difference about setup of split tunneling. Can you post the details of the split tunneling configuration of both machines?
Rick
cisco-sbcsc Sun, 05/18/2008 - 05:53
The split tunnel values are setup on the Firewall as an ACL in the group policy. The ACL is:
standard permit host FileServer_1
standard permit host FileServer_2
standard permit host FileServer_3
standard permit host FileServer_4
standard permit host DNSServer_1
standard permit host DNSServer_2
When I go to Status-> Statistics -> Route Details on both the XP Client and the Vista client they both have the same values for the Secured Routes table (that shows those 6 servers). So I am very confused as to why Vista is acting different.
