DSP card
May 17th, 2008
I replace one AS5300 with AS5400XM (new DSP) cards. The DSP card is S5X-PVDM2-64 (AS5X-FC). How do I config it?
Overall Rating: 4 (1 ratings)
espereir Sun, 07/27/2008 - 22:48
Helo Anita
First, make sure you are running the latest Cisco NextPort SPE Firmware for it to support conferencing/transcoding: http://www.cisco.com/en/US/products/sw/accesssw/ps504/prod_release_note09186a008007e570.html
Then, just follow this configuration sample:
Hope it helps!
pcameron Mon, 08/04/2008 - 03:51
Start here with the AS5350XM and AS5400XM config guide -
Note that the AS5X-FC uses the PVDM2-64 DSP modules (based on the Texas Instruments C5510 DSP's similar to what is used on the 2800/3800 routers) , the rest of the config will be similar to any other voice capable router, so technically your old config <> work by changing over voice port references.
