IPCC Reports error
when I tried to generate some IPCC reports I got this error messege "There are no items available, because you are not authorized to view this data or the items have not been configured in the ICM and/or IPCC database.Contact your administrator to confirm your authorization and the ICM and/or IPCC configuration." I am using the administrator user for the system when I got this error, I am using version 7.1
Use ICM Config to create a user. This will create the user in Active Directory, so make sure the password satisfies the complexity requirements of the domain. Check the WebView box.
Now look on the AD in "Users and Computers" and check under Cisco_root - facility - instance to see if your user is there. You can also fire up the DomainManager.exe in icm\bin and check the membership.
Geoff
david.macias Mon, 05/19/2008 - 04:11
Are you actually using services? There are some reports that will not apply to your installation. Check out the WebView Template Refence Guide.
david
