NPE G1/G2 Gig. Ethernet Options
May 18th, 2008
  • Bronze, 100 points or more
Is there is any options to have NPE G1/G2 with an additional UTP gig ethernet . As I know the only option for Gig Ethernet is PA-GE which is fibre . Is there is any other router comes with 4 Gig Ethernet ? . In my design a router with 4 UTP gig ethernet
Overall Rating: 3 (1 ratings)
paolo bevilacqua Sun, 05/18/2008 - 05:20
  • Hall of Fame,
    Founding Member
PA GE has a GBIT connetor to which you connect a module of your choice including copper.
Note if you're looking for wire-speed routing across all 4 Gbit ports, your best choice would be a layer-3 switch, because the 7200 is incapable of that.
Haris P Sun, 05/18/2008 - 05:35
Hi ,
What you meant by " PA GE has a GBIT connetor to which you connect a module of your choice including copper " ? Is it possible to connect copper on PA-GE , As I know PA-GE has only fibre GBIC ( either GBIC-LX , GBIC-LH or GBIC-ZX ) . Can you tell me how you can connect a module of copper on PA-GE ??
Have a look in this link
http://www.cisco.com/en/US/docs/interfaces_modules/port_adapters/install_upgrade/ethernet/pa-ge_gigabit_ethernet_install_config/2696cabl.html
Haris
