dial peer
May 18th, 2008
Can someone please explain me what is a dial-peer,i am not able to understand it.
The document says that its like a static routing table....
Overall Rating: 4 (1 ratings)
mahmoodmkl Mon, 05/19/2008 - 02:46
Hi Paolo,
Thanks for the reply.
Well i am still confused about this.I will appreciate if u can explain me with a simple example.What i have understand from the dial-peer is that u r defining a path to a destination pattern,is it like this and to define a path to a destination we use the dial-peer command.
Paolo Bevilacqua Mon, 05/19/2008 - 02:52
Yes it is so. Perhaps you need to create a lab to try the configurations in practice and you will understand everything easily.
As a recognition to those providing answers, please rate useful posts with the scrollbox below.
