05-18-2008 06:50 AM - last edited on 03-25-2019 05:39 PM by ciscomoderator
I upgrade from PIX515e to ASA5540 and I am trying to do a packet trace to ensure ACL is correct and the ASDM is giving me an error when trying to do the packet trace "can't contact firewall". How is that if I am using the ASDM. Please Help!
05-18-2008 09:25 AM
Have you tried from the cli?
05-18-2008 09:34 AM
I fix it thanks!!!!!
05-18-2008 04:18 PM
Do a show ver and see what version of ASA OS and ASDM you are running.
packet-tracer
To enable packet tracing capabilities for packet sniffing and network fault isolation, use the packet-tracer commandin privileged EXEC configuration mode. To disable packet capture capabilities, use the no form of this command.
packet-tracer input [src_int] protocol src_addr src_port dest_addr dest_port [detailed] [xml]
http://www.cisco.com/en/US/docs/security/asa/asa81/command/ref/p.html#wp1845801
