Changing IPCC default prompt
May 18th, 2008
I have IPCC 4.0(5)
In IPCC get digit string step ;if time out without entering any digits system plays default prompt"are you still there".
How I can change it?
How I can increase the time out seconds?
Any Idea?
Thx..
Siby Alexander Sun, 05/18/2008 - 19:02
You can play a custom wave file if you edit the Play Prompt step under the Timeout Branch, of the Get Digit String Step.
See page 171, of the below doc has a screenshot. Replace still_there.wav with your wave file.
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_4_0/programming/script_devp/gs_with_scripts/crs401gs.pdf
Initial Timeout (in sec) property of the node sets the timeout for initial input.
See page 169 of the same doc.
Chawki Salhi Tue, 05/20/2008 - 07:09
Those system prompts can be found under the IPCC installation folder. So if i remember:
c:/program files/wfavid/prompts/system/
Best regards,
Chawki
