CME Does Not Call Numbers Start with 0
Answered Question
May 18th, 2008
Hi NetPro,
My 2811 does not dial area codes beginning with 0. This happened after I upgraded the IOS. I rolled back to the previous version, the same problem is still there. I tried a third version, still the same problem. I did not have any configuration changes during the upgrade.
It works when I modify the translation rule to have a non-zero prefix and dial the non-zero code. But the users do not want to dial an addition non-zero prefix to the called number.
Call-forward all to zero-prefixed numbers are working, but 'busy' and 'noan' are not.
The problem seems to be between ip phones and CME. Debug shows the CME does not find a dial-peer, but it sends out busy signal to the phone after it collects the first 2 digits. All later digits are ignored.
Any ideas are appreciated.
Thanks.
Correct Answer by paolo bevilacqua about 8 years 11 months ago
trust me, it's a configuration issue. Send it here and it will be clear why.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Sun, 05/18/2008 - 23:29
  • Hall of Fame,
    Founding Member
Chuan Liu Mon, 05/19/2008 - 02:31
Hi Paolo,
I believe you, so I compared a few times the current config against the old working configuration. But I failed to find any differences.
Please find attached a reduced version of the current config.
Thanks in advance.
paolo bevilacqua Mon, 05/19/2008 - 02:42
  • Hall of Fame,
    Founding Member
Hi, the translation rules makes a bit difficult to understand what is the wanted result, can you check with "debug ccsip message" what number is being sent out.
Also if you have fixed lengh numbers in your country I suggest you configure a DP without T to speed-up calls.
Rule 112 can be much simplified but I guess that is not the problem now.
Chuan Liu Mon, 05/19/2008 - 02:56
This is a 2 year old system. I started looking after it 2 months ago. I upgraded the IOS for a non-voip feature, which with no reason broke the MS VPN. So I changed back the IOS and VPN is fixed, but the voip problem occurred.
I am in New Zealand. I will do the debug test the first thing tomorrow morning.
The translation rules are not triggered in this case, no dial-peer is selected before cme sends out busy signals. On the phone display, only the first 2 digits are displayed as the called number. In a successful call, the display should include all the dialed digits plus the translated prefix.
Thank you very much.
Chuan Liu Mon, 05/19/2008 - 12:16
Hi Paolo,
"debug ccsip message" shows nothing when I call a number starting with 0. No DP is triggered:
"debug voip dialpeer" shows: digit 0 is the only called number.
000363: May 20 08:05:45.641: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=099254311, Called Number=, Voice-Interface=0x48B91B80,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
000364: May 20 08:05:45.641: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20038
000365: May 20 08:05:46.161: //-1/CD17E31680E9/DPM/dpMatchPeersCore:
Calling Number=, Called Number=0, Peer Info Type=DIALPEER_INFO_SPEECH
000366: May 20 08:05:46.161: //-1/CD17E31680E9/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=0
tt-triton-cme#
000367: May 20 08:05:46.161: //-1/CD17E31680E9/DPM/dpMatchPeersCore:
Result=Partial Matches(1) after DP_MATCH_DEST
000368: May 20 08:05:46.161: //-1/CD17E31680E9/DPM/dpMatchPeersMoreArg:
Result=MORE_DIGITS_NEEDED(1)
"debug voip ccapi inout" and "debug ephone detail" are attached.
Thanks.
paolo bevilacqua Mon, 05/19/2008 - 12:31
  • Hall of Fame,
    Founding Member
Can you beging configure a more proper DO?
Like, destination-pattern 0........
Avoid using T for fixed lenght numbers.
Chuan Liu Mon, 05/19/2008 - 12:42
I tried a specific DP for a mobile number. "debug ccsip message" still shows nothing.
dial-peer voice 21856588 voip
translation-profile outgoing outgoing-calls
destination-pattern 021856588
redirect ip2ip
b2bua
session protocol sipv2
session target ipv4:202.162.176.51
dtmf-relay rtp-nte
codec g711ulaw
Thanks.
paolo bevilacqua Mon, 05/19/2008 - 12:51
  • Hall of Fame,
    Founding Member
That is a bit strange, suggest you experiment with a barebon DP to see if at some point the call goes out and then start from there.
Chuan Liu Mon, 05/19/2008 - 12:58
Hi Paolo,
What do you mean by bearbon DP?
I doubt this is something related to FW that does not match the IOS, as this happened only after I changed IOS. And non-zero numbers are OK.
Thanks.
Chuan Liu Mon, 05/19/2008 - 19:05
Hi Paolo,
You are absolutely right. It is the configuration issue. I have found it at last.
The older version IOS used 'after-hours exempt'; the newer IOS does not take this command. Instead, it takes 'after-hour exempt'. There is no 's'.
Can I blame Cisco for this?
Thanks for your direction.
paolo bevilacqua Mon, 05/19/2008 - 23:22
  • Hall of Fame,
    Founding Member
No problem. I personally blame cisco for anything, they are not offended.
Thanks for the nice rating and good luck!
