2811 HWIC 4 ESW
May 18th, 2008
Hello All,
I have a Cisco 2811 running IOS adventerprisek9-mz.12.4-15.T and a
HWIC-4ESW POE installed. When I plug in a 7960 phone it does not power up....thoughts please
paolo bevilacqua Sun, 05/18/2008 - 23:30
  • Hall of Fame,
    Founding Member
Do you have the POE PS ? "show env" to know.
paolo bevilacqua Mon, 05/19/2008 - 07:50
  • Hall of Fame,
    Founding Member
Do you have power inline under interface? Beside that I'd to see "show diag" and "show env".
Sushil Kumar Katre Tue, 05/20/2008 - 00:37
  • Gold, 750 points or more
Can you please paste the show diag output and cross verify if you see "ILPM-4=" part number in that output.
Also check if the power supply which you have is "AC-IP".
-> Sushil
lagos Tue, 05/20/2008 - 04:35
  • Cisco Employee,
If you have the ILPM module for the HWIC and a POE enabled power supply in the router - make sure you have the cable that runs from the poe supply to the motherboard.
HTH.
Jason Aarons Tue, 05/20/2008 - 10:32
  • Bronze, 100 points or more
Likely power supply is not AC-IP model.
