Portchannel and Trunk inconsistency
May 18th, 2008
Dear All,
Hi, I have to Cisco WS-4506 acting as Core in my production network. There are multiple L2 vlans and SVIs created on both of the switches with one switch acting as primary for one VLAN and other acting as secondary for one VLAN (I am running HSRP on per VLAN for redundancy for LAN). Both Switches are connected through one Fiber trunk on their Supervisor card and additionally 2 Gig ports are part of Etherchannel as well on each of the switch.
Please clarify if there will be any spanning tree issue or any inconsistency due to having L2 Etherchannel and additionally L2 Fiber trunk. Because I am facing issue with my Primary Core switch repeatedly. At times my primary core switch stop functioning and throws following log messages on console:
%% Low on memory; try again later
After this any type of traffic can't flow from my Primary switch and Secondary switch can't takeover.
Please find the attached logs and snapshot of configuration at both switches from my secondary core switch when the problem occurs at Primary switch. I can't login to my primary core switch when its in middle of the problem but it starts functioning after I restart it.
Should I disable Logging buffer to avoid memory problem in my Primary core switch or what will be the ideal solution!
Appreciate your earliest reponse!
Overall Rating: 3 (1 ratings)
royalblues Mon, 05/19/2008 - 01:08
  • Green, 3000 points or more
Under very low memory conditions, IOS does not allow console/telnet connections to the device
disabling unnecessary processes should help in reducing the memory
you can try disabling buffer logging and instead send the logs to a syslog server.
Also there are a lot of port flapping messages which might point to a spaning tree loop. Try to fix them as well
Have a look at this Bug ID CSCed65890
Narayan
samuneer123 Mon, 05/19/2008 - 02:05
Dear Narayan,
Thanks for the reply. But isn't anything wrong with design of connecting Fiber trunk port on Supervisor card and also two Gig ports from each of the switch in L2 port channel /Etherchannel acting as trunk at the same time.
What about the mismatch of the configuration of between members of the Portchannel between switches. Shouldn't I allow the same Vlan range in the trunk on both of the switches.
Primary core Switch:
interface GigabitEthernet3/1
switchport trunk allowed vlan 2-4094
switchport mode dynamic desirable
channel-group 1 mode desirable
interface GigabitEthernet3/2
interface Port-channel1
switchport
Secondary Core Switch:
switchport
Is the same thing which is causing the frequent port flap messages between Vlan1 and Vlan 2 (see the attached file for logs).
Appreciate more responses!!
With regards,
Sarfaraz
bava_ccna Mon, 05/19/2008 - 02:29
i am also getting same flapping error in my Cisco 4506 switch.Initially i suspect that there might a loop in our network and again i found that there is no such loops in my network
Any help is appreciated
Cheers
Bava
samuneer123 Mon, 05/19/2008 - 04:28
Dear All,
I have looked at the TAC Bug toolkit.
CSCed65890 Bug Details
Request to have ability for reserving memory for exec session
Workaround:
No workaround
Can anybody tell me how can I allocate necessary memeory for exec session to avoid running into Low on memory problem ?
With Regards,
Sarfaraz
samuneer123 Mon, 05/19/2008 - 05:08
Dear muca,
This document doesn't relate to the problem that I am facing with these switches.
I am facing difficulty to find the exact root cause of this problem.
With regards,
Sarfaraz
rmujeeb81 Mon, 05/19/2008 - 07:28
Dear Sarfaraz,
If you think that there is something goes wrong with spanning tree then you can only use the ether channel between these switches. Few other steps you can take to prevent additional messages/packets forwarding between both switches like,
- Disable DTP on all trunk links and manually configure trunks on both side.
- Manualy configure etherchannel to avoid negotiation by PAGP on both sides.
Mujeeb
samuneer123 Mon, 05/19/2008 - 09:03
Dear Mujeeb,
Thanks for your input. Thats what I did right now for only etherchannel configuration and Fiber trunk port (which is not part of Portchannel) for rest of the port configuration I will do it soon. Initially the only reason I suspected was spanning tree loop causing frequent flaps as per seen through log but this design with Fiber trunk port with additional Portchannel (2 member Gig ports on GBIC-LAN module) is running fine since so long.
This "Low on memory" issue is re-ocurring frequently once every 3 weeks atleast causing service disruption.
I will lock down DTP and other unnecessary services then analyze if things are getting better!
