Dequeue step - real time stats
May 18th, 2008
Hi everyone,
I am meeting a problem when using the dequeue step. On the real time stats (CSD), I see calls remaining in queue even after dequeuing them.
I am actually using CSQ (no agents for that queue) for reporting and what I do is the following:
1-select resource step
2-in the queue branch: dequeue step
IPCCX 4.0(5) SR1
Thanks a lot for your help !
smalkeric Fri, 05/23/2008 - 06:59
  • Silver, 250 points or more
One use for the dequeue step is if you have used the select resource step more than once and you then queue the call, it will queue against all of the CSQ's chosen. You may want to search for an agent in multiple CSQ's but if none are available, queue to one specific CSQ. The dequeue step can be used then.
Chawki Salhi Sun, 05/25/2008 - 23:19
Dear Smalkeric,
I am actually using a Select ressource on a queue where there are no agents. This is only done to find which calls got through one of my callflow branch in the historical reporting.
But for the real-time reporting, I see my call staying in the queue even if I do a dequeue step just after the select resource step on the same CSQ.
Thanks again for your help and if you have any idea.
Chawki
amaia.lesta@gru... Sat, 07/12/2008 - 00:48
Dear all,
I am experiencing the same issue. I queue a call in Q1, if there are not ready agents y queue it in Q2 and also mantain it in Q1.
If there are no agents in Q2 I dequeue it from Q2, queue it in Q3 and mantain it in Q1.
If there are no agents in Q3 I dequeue it from Q2, queue it in Q4 and mantain it in Q1.
If there are no agents in Q4 I dequeue it and mantain it in Q1.
In fact when I debug the script I check that the behaviour is OK. It is queued and dequeued as state.
But in the CSD the call is stated to be in more than one queue although it isn't true. In fact, if I place 3 calls from the same cellular phone one after the other, mantaining the agents' state and without any other call in the system, the CSD shows different behaviours in each call. Sometimes the call is in 3 calls, sometimes in 2,...
Do you know how to solve it?
Thanks in advance.
Amaia
Chawki Salhi Wed, 07/30/2008 - 04:50
I am still meeting this issue unfortunately. I have opened a TAC case but there are no solutions...
amaia.lesta@gru... Tue, 08/05/2008 - 04:14
Thank you very much for your kind update, chawki.salhi. If you happen to get any new form TAC, please, let us know.
Best regards,
Amaia
