DMA Tool 6.1
Answered Question
May 18th, 2008
is it possible to put in the DMA-File a second time in a running CCM 6.1 ?
David
Correct Answer by Jaime Valencia about 9 years 2 months ago
no it is not possible, the DMA file is to be used during the installation process and on a fresh system
you would need to rebuild the server and use the DMA during install or use a backup from 6.x
javalenc
if this helps, please rate
Overall Rating: 4 (1 ratings)
Correct Answer
Jaime Valencia Mon, 05/19/2008 - 03:48
  • Cisco Employee,
  • Hall of Fame,
    2011
javalenc
