Jaime Valencia Mon, 05/19/2008 - 04:08
was going to reply you on the other thread but i see you opened this one, the short answer is that there is no command to do this.
the only way i found out would be to configure a TCL script and maybe a radius to achieve what you want
check with your telco if they can do something about this, since you mention this are FXOs it shouldn't be hard to id the call for them
BTW: please open the threads on the right forum, i don't believe this is a video over IP question
javalenc
if this helps, please rate
haarisalibaig Mon, 05/19/2008 - 04:45
Thanks a lot..
Actually by fluke I read Video as Voice, after reading your email I realised it is Video not Voice...
So in conclusion there is no way to achieve this!!!this is going to be hard as we replaced Nortel claiming we will give all what exist & even more...as you are in Cisco try to escalate..I am sure Cisco will have more requests like these....
thanks for your sugestion...
Jaime Valencia Mon, 05/19/2008 - 04:50
there have been a lot of people asking for this actually, but the request should not come from me (i don't own myself a CUCM =) ). it should come from all the guys out there that buy the products and would like to have the feature.
you may reach your AM to see if you can open a PER (Product Enhancement Request) so it can be on a future release.
javalenc
