Configuration Fatality ISP
May 19th, 2008
Regards to all, I have a problem at the moment of forming the connection of my supplier of Internet. I have proved everything possible but all the results are negative.
The parameters of configuration are:
VPI:8 VCI:32 IP: 80.80.80.80/24 Encap: MAC Encapsulated Routing Someone can help me with this problem.
Pardon for my English :(
paolo bevilacqua Mon, 05/19/2008 - 02:10
  • Hall of Fame,
    Founding Member
bridge irb
bridge 1 route ip
int atm0
no ip address
int atm0.1 point-to-point
no ip address
bridge-group 1
pvc 8/32
int bvi1
ip address ..
ip nat outside
hope this helps, please rate post if it does!
nachogdiaz Mon, 05/19/2008 - 02:32
Hello p.bevilacqua!, thank you for helping myself but I continue without coming to Internet.
I put a sh run:
version 12.4
no service pad
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
crypto pki trustpoint TP-self-signed-1935357841
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1935357841
revocation-check none
rsakeypair TP-self-signed-1935357841
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip domain lookup
ip domain name yourdomain.com
archive
log config
hidekeys
bridge irb
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 8/32
bridge-group 1
bridge-group 1 spanning-disabled
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.10.10.1 255.255.255.248
ip tcp adjust-mss 1452
interface BVI1
ip address X.X.X.X 255.255.255.0
ip nat outside
ip virtual-reassembly
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit 10.10.10.0 0.0.0.7
no cdp run
control-plane
bridge 1 route ip
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
That can be failing?
paolo bevilacqua Mon, 05/19/2008 - 02:49
  • Hall of Fame,
    Founding Member
Hola,
You are missing:
- "bridge-group 1" under atm0.1
- default route like 0.0.0.0 0.0.0.0 x.x.x.x
- ip nat inside source list XX interface bvi1 overload
- and ACL for the above
Also check that you're connect in first place with "show dsl interface".
nachogdiaz Mon, 05/19/2008 - 03:09
I also meet very lost
I have put this configuration but it continues without working.
version 12.4
no service pad
hostname yourname
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
import all
lease 0 2
no ip domain lookup
archive
log config
hidekeys
bridge irb
interface ATM0
no ip address
description $ES_WAN$
pvc 8/32
encapsulation aal5snap
bridge-group 1
interface Vlan1
interface BVI1
ip address X.129.224.68 255.255.255.0
ip nat outside
ip route 0.0.0.0 0.0.0.0 ATM0
ip http server
no cdp run
control-plane
bridge 1 route ip
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
end
paolo bevilacqua Mon, 05/19/2008 - 03:12
  • Hall of Fame,
    Founding Member
Hi, you're entering the wrong commands. Please read my message and enter the command correctly.
nachogdiaz Mon, 05/19/2008 - 03:32
I am sorry, but not as put the commands that you have indicated me, you can help do it to me please
paolo bevilacqua Mon, 05/19/2008 - 03:49
  • Hall of Fame,
    Founding Member
Most important is ip route 0.0.0.0 0.0.0.0 must have IP of default GW and not an interface.
nachogdiaz Mon, 05/19/2008 - 04:12
Hello, i configured:
ip route 0.0.0.0 0.0.0.0 ATM0.1 KO
ip route 0.0.0.0 0.0.0.0 BVI1 KO
On having done one sh ip inter brief:
FastEthernet0 unassigned YES unset up up
FastEthernet1 unassigned YES unset up down
FastEthernet2 unassigned YES unset up down
FastEthernet3 unassigned YES unset up down
ATM0 unassigned YES manual up up
ATM0.1 unassigned YES manual up up
Vlan1 10.10.10.1 YES NVRAM up up
BVI1 X.129.224.68 YES manual down down
NVI0 unassigned NO unset up up
paolo bevilacqua Mon, 05/19/2008 - 12:29
  • Hall of Fame,
    Founding Member
Hi, what I'm trying to tell you, remove the above static routes and use instead the IP address of deault gateway as communicated by the ISP.
