Why are my log messages being dropped?
May 19th, 2008
Here's my output from "sh log" (note the syslog part):
Syslog logging: enabled (96 messages dropped, 259 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
Console logging: disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 464 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
File logging: disabled
Trap logging: level informational, 206 message lines logged
Logging to 10.14.9.1, 206 message lines logged, xml disabled,
filtering disabled
Logging to 10.14.9.19, 206 message lines logged, xml disabled,
filtering disabled
Why are messages to my syslog server being dropped (96 so far)?
Dan
Jon Marshall Mon, 05/19/2008 - 06:18
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Dan
As far as i know sylog messages will be dropped when
a) the router hasn't made a connection to the syslog server yet ie. when it is rebooting the router may try to send a syslog message before it has established a connection with syslog server
b) the syslog server has gone down.
Has either of these things happened ?
Jon
binod1801 Tue, 05/20/2008 - 04:28
The syslog protocol uses port no 514. The destination port 514 must be open in any intermediate or terminal devices like firewall or router.
binod1801 Tue, 05/20/2008 - 04:29
The syslog protocol uses port no 514. The destination port 514 (UDP) must be open in any intermediate or terminal devices like firewall or router.
