Re-directing outbound traffic to DMZ
Answered Question
May 19th, 2008
I'm pretty sure I've seen a solution to this problem before but I just can't seem to find it...
I have LAN users trying to access servers in the DMZ via their public IP's. They go out the outside interface to do this but are getting dropped as spoofed packets when they come back, how can I redirect this traffic to go directly to the DMZ?
Thanks.
Correct Answer by acomiskey about 9 years 2 months ago
static (dmz,inside) netmask 255.255.255.255
That should do the trick.
Overall Rating: 5 (1 ratings)
Correct Answer
acomiskey Mon, 05/19/2008 - 05:06
  • Green, 3000 points or more
d.donnelly Mon, 05/19/2008 - 05:32
Thanks for your response, as a workaround we actually routed traffic for that particular subnet out the backup outside interface, your way looks better.
Just gotta try get them to let me change it now!
