1. TACAS+ Accounting and Logged in Users report is not working on ACS 4.1(1
May 19th, 2008
I am facing problem with ACS 4.1 accounting, TACAS+ Accounting and Logged in Users report are not working, the csv file is been generated but nothing is showened in the file.
I have checked the documents related to ACS 4.1, it says that there is a bug related to command accounting “CSCsg97429 - TACACS+ Command Accounting does not work in ACS 4.1(1) Build 23”.
Tried upgrading the same with the patch applAcs-4.1.1.23.3.zip, still it is not working.
Other reports are working fine.
1. TACAS+ Accounting - not working
2. Logged in Users - not working
3. TACAS+ Administration - working
4. Passed Authentication - working
5. Failed Attempts - working
Any suggestions or any idea, please revert.
Vineet
Jagdeep Gambhir Mon, 05/19/2008 - 06:02
  • Red, 2250 points or more
Vineet,
What all commands you have on the aaa-cleint ?
Do you have this command .
AAASWITCH(config)#aaa accounting exec default start-stop group tacacs+
~JG
Do rate helpful posts
vineet_tiru Mon, 05/19/2008 - 20:27
Yes I have configured the command “aaa accounting exec default start-stop group tacacs+”
As I have mentioned all the other reports are working. Which user and when he has logged in and what commands he has used. Only the TACAS+ Accounting and logned user is not working.
Vineet
