minor issue ASA 5505
May 19th, 2008
I just installed ASA 5505 using at vlan2 external ip n at vlan 1 internal ip.. I can't ping external ip form internal ip n reverse. ?
alanajjar Mon, 05/19/2008 - 06:35
To enable ASA interfaces to reply on ping command, use the following command :
icmp permit ip_address net_mask [icmp_type] if_name
ip_address is the ips that will be allowed to ping.
icmp_type is the message type, its optional you can use any to enable all icmp messages.
if_name is the name of the interface which will be pinged.
example ,if you want to grant icmp on outside interface for host 10.1.1.1
then the command will be:
icmp permit host 10.1.1.1 outside
with regards
blue4cisco Mon, 05/19/2008 - 20:28
That's nice I try it.. can u tell me how do I access ASA cli mode remotely ?
alanajjar Mon, 05/19/2008 - 21:18
You can access ASA CLI by using telnet or SSH. for telnet access configure these commands :
telnet ip_addr mask if_name
ip_address is the address or range of addresses that will grant access the ASA. example:
telnet 10.1.1.0 255.255.255.0 inside
to define password for telnet use the command :
passwd your_password
to use ssh, you need to define the following:
1- ssh ip_addr mask if_name
2- define a crypto key, use the command :
crypto key generate rsa general-keys
3- define the AAA authentication for users that will use ssh , use :
aaa authentication ssh console LOCAL
LOCAL word is case sensitive
4- define accounts for users to access the ASA :
username user password password
please rate the post if it solve the problem.
with regards
