2801 - installing a vwic21mft-t1/e1 - what slot?
May 19th, 2008
Hi. I've got a new 2801 here and an interface card for it. Now i've got 4 available slots for it, but im sure I read somewhere that if I put this vwic2 card in one of the slots I could damage it.. but I cant find that document now grrrr.
What slot should i go for ?
Thanks! :)
Paolo Bevilacqua Mon, 05/19/2008 - 04:05
  • Hall of Fame,
    Founding Member
It's written on the back of the router. Slot 0 is voice only.
dezoconnor Mon, 05/19/2008 - 04:12
  • Silver, 250 points or more
I currently can't find the doc myself but if I remember correctly doesn't it tell you on the front of the router itself what card you can install in each slot? i.e slot 0 VWIC, slot 1 FXO-FXS.
davieshuw Mon, 05/19/2008 - 04:22
well what ive got is:
Slot 3 nothing written on it
Slot 2 Only VIC's and WIC's
Slot 1 nothing written on it
Slot 0 Only accepts VIC's
As my card is a VWIC 2 not sure what one I go for
Sushil Kumar Katre Mon, 05/19/2008 - 04:23
  • Gold, 750 points or more
on 2801 router all the slots supports VWIC module.
So you can install it on any of the slots.
• 4 slots; 2 slots support HWIC, WIC, VIC, or VWIC type modules
• 1 slot supports WIC, VIC, or VWIC type modules
• 1 slot supports VIC or VWIC type modules
-> Sushil
davieshuw Mon, 05/19/2008 - 04:26
ah ok, well i've slotted it into slot 3. However it doesn't show up when I run the show interface command
Sushil Kumar Katre Mon, 05/19/2008 - 04:29
can you let me know the IOS file name you are running.
you should have minimum IP Voice.
davieshuw Mon, 05/19/2008 - 04:31
Cisco IOS Software, 2801 Software (C2801-SPSERVICESK9-M), Version 12.4(9)T7, RE)
System image file is "flash:c2801-spservicesk9-mz.124-9.T7.bin"
dezoconnor Mon, 05/19/2008 - 04:44
Ah, you're using t1/e1. You need to configure the card type
global config>card type e1
If you're running 12.4 spsvcs this should work
davieshuw Mon, 05/19/2008 - 07:12
I've put the card in slot 2.
I've entered the command:
card type e1 0 2
and th LP light lights up green or half a second, then the AL light is amber.
davieshuw Mon, 05/19/2008 - 06:03
WIC/VIC Slot 2:
VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1
Hardware Revision : 0.0
Top Assy. Part Number : 800-22628-05
Board Revision : B0
Deviation Number : 0
Fab Version : 04
PCB Serial Number : FOC12021G7S
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : VWIC2-1MFT-T1/E1
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 FD 41 00 00 C0 46 03 20 00 58 64 05
0x10: 42 42 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
0x20: 32 30 32 31 47 37 53 03 00 81 00 00 00 00 04 00
0x30: CB 90 56 57 49 43 32 2D 31 4D 46 54 2D 54 31 2F
0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
davieshuw Mon, 05/19/2008 - 08:34
card type e1 0 2
