CUCM 6.1 and SIP-trunk through CUBE
May 19th, 2008
This config do not work, pl check and give me your instructions:
voice service voip
allow-connections sip to sip
redirect ip2ip
registrar server expires max 600 min 60
transport switch udp tcp
no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
dial-peer voice 1 voip
description TO-SIP-PROVIDER
service session
destination-pattern .T
redirect ip2ip
voice-class codec 1
voice-class sip transport switch udp tcp
session protocol sipv2
session target sip-server
session transport udp
dtmf-relay sip-notify rtp-nte
no vad
dial-peer voice 2 voip
description TO-CUCM
service session
destination-pattern 1118
redirect ip2ip
voice-class codec 1
session target ipv4:
incoming called-number .T
dtmf-relay rtp-nte
credentials username user password 083343570815514346 realm
authentication username [email protected] password 7 0449041F0E2D181A5D
nat symmetric role passive
nat symmetric check-media-src
no remote-party-id
mwi-server expires 3600 port 5060 transport udp
registrar expires 3600
Tommer Catlin Mon, 05/19/2008 - 06:34
You have SIP Credentials in there. I would take this out while you are testing to avoid any possibly stops from this.
Also, if you are going from 6.1 to CUBE, I thought you could go directly from server to server and not through the IOS router?
Just create the sip trunk and point it to the CUBE server and vice versa.
Check your SIP security profile and see what port it is listening on. 5060 or 5070?
It also looks like you have SIP trunk to a provider?
Possibly if it could help if you give us some more background on how this is setup.
Limarenko Mon, 10/13/2008 - 11:46
For example I have only one ip address from provider. In this case it will work isp(sip-server)-router with nat -callmanager (natted to external IP address of the router)-phones ?
