UCM 6.1 : DRS Backup History Not Updating
May 19th, 2008
Has anyone else had the issue of DRS not updating the Backup History with the latest information? I have it set to backup to a network location nightly, saving the previous two backups and it doesn't show that it has ran, however I can verify that the expected backups are available on my SFTP server.
Anyone else seen this? Is this a known bug or is there something I can do to make sure it displays the latest information?
Anonymous (not verified) Fri, 05/23/2008 - 06:13
At the beginning of the DRF backup try to login to the SFTP server to make sure it is available. Also it may be caused by some intermittent network issue or due to lack of space. So you have to confirm that there is more than 15 GB space. Or try to reboot SFTP server. You can refer the bug CSCsj12178 for any workarounds.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/drs/6_0_1/drs/drsag601.html
