LACP trunk from 6509 (CatOS) to Linksys SRW2048 Gig Switch
May 19th, 2008
Has anyone made this work? Currently have
LACP trunk between two 6509's working fine.
Using two ports on my X6408A-GBIC blade in 6509 to trunk dot1q to two 2950 switches.
Would like to use two more ports on same 6408 blade to LACP to the Linksys.
greggswitzer Mon, 05/19/2008 - 09:32
That's great.
Question: The Cisco switch requires setting the entire blade to LACP protocol. Will that
cause me problems with the two ports currently running dot1q(PAgP)to two 2950's?
Edison Ortiz Mon, 05/19/2008 - 09:37
  • Hall of Fame,
    Founding Member
You can have both protocols running on the same module.
HTH,
__
Edison.
